Old 10-10-2015, 09:05 PM
Default Whats a good brush killer?
I have quite a bit of brush ,vines,wild honey suckel etc . To kill I have tried 2_3 different killers but has not done much damage to it .
Was wondering what you use , a qt would do it if it kills with 2,2 treatments
Old 10-10-2015, 09:10 PM
rdehli rdehli is offline
use Tordon. it will kill all that stuff. 1 application
Old 10-10-2015, 10:50 PM
drcjv's Avatar
drcjv drcjv is offline
Mix Sythe with round up and on a hot day you can watch it die before your eyes
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 10-11-2015, 03:42 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
We always use 2-4d & tordon...
Old 10-11-2015, 11:47 AM
I use the poison ivy and heavy brush cutter. Have used several different brands from K-Mart to Tractor Supply, they all seem to work good.
Around here we have the Multa floral rose bushes, and it will kill them.
Old 10-11-2015, 11:57 PM
bocephus1991's Avatar
Dad used to use tordon and crop oil with 2-4d
Brian
Old 10-17-2015, 09:47 PM
Thanks for the advice I used ortho as it was all they had here in qt size ,guess they sold out
It finally did kill the kudsu or the cold did l will try the ones you said . In the spring
Old 10-23-2015, 02:16 PM
j4c11's Avatar
j4c11 j4c11 is offline
Looks like Tordon already has 2,4-D in it. Tried some glyphosate on some sort of climbing vine and it did nothing. Going to try some 2-4D and if that doesn't do it I'll try Tordon.
