Old 10-24-2015, 12:31 PM
gdheck's Avatar
gdheck gdheck is offline
Default Super snow blade mounting problems
I have a manual angle 1991 and later blade that is extremely hard to get the sub frame mounted on my 2072. It is hard to get it to latch onto the quick hitch in the front and when you finally get that latched, the pin doesn't want to go in the rear mount.
I also have a pre-91 power angle blade that went on the same 2072 smooth as can be yesterday. The only thing I had to do was trim a corner off the rear end brace where the larger rear mounts hit. But, I couldn't get a bolt in one of the front frame holes when I was done.
Are these common problems with these blades or do I have two that are screwed up? I can't see anything obviously wrong with either one. I'm thinking they were just built with sloppy tolerances.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 10-24-2015, 02:18 PM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
When I bought my 2182 new I had to die grind some of the holes the first time it was mounted.
