I was wondering if anyone has resurfaced a series block themselves.? I wasn't planning to build this engine but I ended up looking into it and found that it was in good shape inside. The piston and rod were shot from overheating, I assume from low oil and the #30 carb on it. I already have the parts that were ordered for another engine that has an egg cylinder. I've found with this new engine that the cylinder deck isn't flat. I know that the head will clear this rise but I'd like to flatten the deck. The local machine shop quoted me $225 to surface it. I really don't think I want to spend that on just surfacing the block. So has anyone done this at home with just the basic tools? If so how and what did you do and use?
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment. ![]() |
![]() Quote:
Really, $225 to surface it?
![]() I resurfaced the top of my K301 block at work during my lunch time ( 30 minutes ) I even had time to eat my sandwich ![]() I need to get a Bridgeport mill. |
Thats a ridiculous amount.
Like Jeff said it doesn't take long.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
I do agree that $225.00 is a lot of money for a half hour job. Maybe that shop is geared more toward a different type of work, or they have enough business in the kind of work that they normally do, that setting up and then doing the job is (and I mean this in the kindest sense) more trouble for them than it is really worth.
Just because one shop wants a ton of money to do the work doesn't mean that another shop wouldn't gladly take the job for a more reasonable price. I'd try shopping around a little. On the other side of the coin... Even IF you already have a suitable existing building, go buy your own vertical mill, get a good 3 phase converter, get everything wired, buy a DRO, 3 power feeds, a vice, an indexing fixture, a chuck, then start buying tooling and set up equipment. THEN make your money back. Luckily, you can get your lathe set up and running for about half the cost of the mill and related items.
Send it to Jeff in PA along with a sandwich he might do it for you.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Unless your experienced and have the tools I'd have a machine shop do it. I'd shop around a get some price quotes. Or you could send it to Jeff!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
With a half decent milling machine that job shouldn't be too bad.. I'd shop around a bit... I have a friend that loves to play with his mill.. He would probably do it for free just to have a project! too bad you aren't closer to me.
I wouldn't attempt it without the proper tools or machinery.. Good luck! ![]()
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Easy to set up and fly cut on a Bridgeport.
I'd look for another shop near you. |
![]() Quote:
