Old 11-03-2015, 07:33 PM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default Control valve leak
Hello. I have a cub cadet 1711 that I just recently purchased and the control valve is leaking at the top of the spool. I am assuming it is leaking by an o-ring. Is the repairable? If so, any advice on how to repair? What size o-ring do I need? Any advice would be greatly appreciated.
Thanks,
Earl
Original, 1512, ih 982, ih 682
Old 11-03-2015, 10:55 PM
Don't know if your control valve is like mine, but on my 782 single spool, it was an easy fix and the 2 "O" rings I got for less than a dollar @ my Ace hwd.
Do use lube when sliding the spool back into the valve body .
Can't remember which end I put in first but thinking I had to put one ring on and push the spool in and out the other end a bit and put that ring on and push it back in.
I couldn't put them both on and slide it in with out damaging the "O" rings
( typical).
Old 11-03-2015, 11:07 PM
Earl, I wanna say they are #110 but I can't find my notes and some of the valves are different. Here is a pic of an early built 1811 spool that I rebuilt.
Old 11-04-2015, 08:55 PM
Ewilliams's Avatar
Default valve
Thanks for the help. I found the o ring size on the partstree website.
Earl
