Old 11-05-2015, 02:14 PM
rpking rpking is offline
Default Charging issues
I'm having issues with my 122
I had my starter-generator and regulator checked at an electrical shop
the SG tested good but the regulator was bad
so I bought a new one and put it back together, but I'm still having the same problem as before.
When I test to see if the system is charging my meter readings are all over the place, jumping from 8 volts to 18 volts and everywhere in between, very erratic and it never settles on any one reading.
When at the electrical shop they hooked my SG up with the new regulator and it worked fine.
So it leads me to believe that I have some other problem?
I tried to polarize the regulator by touching a jumper wire on the GEN. terminal and the BAT. terminal, as soon as I touched the wire on the terminals the SG started to turn the engine over, the key was off.
Does anyone know what my problem is?
I tried my meter on one of my other cadets and it works fine.
P.S. the wiring harness is new, the tractor starts and runs fine other than the described problem.
Thanks everyone.
Old 11-05-2015, 02:25 PM
Is the voltage regulator getting good ground?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-05-2015, 02:33 PM
AS A TEST.........
Run a long jumper wire from the Battery Negative Terminal to the V/R case or housing. Let us know the results.
Old 11-05-2015, 05:13 PM
Do the terminals on the old and new regulators have the same markings in the same locations?
Old 11-06-2015, 11:55 AM
I worked on my charging issues a little bit today,
I hooked a wire from the regulator mount to the negative battery post, same result, crazy numbers jumping all over the place.
Hooked the same wire from the negative battery terminal to the SG, same result.
Also hooked to one of the engine mounting bolts, same result, so I would say everything is grounded properly.
The old and new regulators are the same, so I'm sure I have it wired correctly.
The system does charge, after letting the tractor run for a few minutes I get a higher voltage reading at the battery with the engine not running than I get when I checked it before I started the engine.
I'm at a loss, I guess as long as it is charging the battery I will try to let it go, it bugs me though, I would like to figure it out.
Thanks for the help
Old 11-06-2015, 12:30 PM
the SG tested good but the regulator was bad so I bought a new one
What did you buy....????
Old 11-06-2015, 01:14 PM
a new voltage regulator.... DR Prem Mech Reg 12V 231-12004
Old 11-06-2015, 05:15 PM
From my research....
You have this....231-12004 ---------> 231-12032
As you can see from the image, it is only rated for 7-9 Amps.
The S/G puts out 15 Amps. The correct V/R would be: 1118988 Delco-Remy or Cub Cadet IH-545130-R92
It looks like you have the wrong V/R based on a poor substitution.
Old 11-07-2015, 02:37 AM
Thanks for your reply, I will have to try and get the correct part
Old 11-10-2015, 03:22 AM
Well I tried a Delco-Remy 1118988 voltage regulator..... same result
I tried a SG off of another cadet I have..... same result
I wonder if it could be component that the voltage goes through before gets to the battery, key switch or possibly the solenoid????
