Old 11-06-2015, 07:56 PM
inboardnut's Avatar
inboardnut inboardnut is offline
Default 1772 ..New fuel pump.. hard cold start?
I just installed a new Kubota fuel pump on my 1772. Now the tractor is very hard to start when its been setting. Once it does start and warms up, you can turn it off and it will re-start easily. Before old fuel pump crapped out, it always started fine.
Any idea what is up?
Old 11-06-2015, 08:05 PM
Bad spark plugs.
Are the glow plugs working? Before you say yes, are you sure? Are they getting 12V?
Do you have a fuel restriction? Are you sure?
Old 11-06-2015, 08:38 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Bad spark plugs.
All possibilities, except the spark plugs! Did you bleed the injectors?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-06-2015, 08:50 PM
inboardnut's Avatar
Bad spark plugs.
Wow...Thanks for the suggestion...I think I just found the problem. I had checked fuel delivery when I installed the new pump and it was good.
I did the glow plug upgrade a year or two ago. I just checked voltage and have 12.6 volts on the battery side of the solenoid, but only 4 to 5 volts on the load/glow plug side. I ran a jumper across the solenoid terminals to get the full voltage to the glow plugs and she started right up!!!
Dont think I have ever seen a low voltage situation on a solenoid. .. thought it either worked or not. Guess its time for another new solenoid.
Thanks for the info!!!
Old 11-06-2015, 08:53 PM
There is a big contact plate in the solenoid. It can arc on it, making the contact point have a poor connection. Seen it many times. Glad you got it!!
Old 11-06-2015, 09:20 PM
inboardnut's Avatar
I see the "almost new" solenoid has a Made in China sticker on it....go figure...
