Old 11-11-2015, 05:54 PM
Default Ready for winter
Weather was great here today (70's) so I spent the day getting all my toys ready for winter. Cleaned decks, drained all the gas tanks and ran everything dry. Then I put the plow and chains on the BX. Ryan will be happy now.
Old 11-11-2015, 05:56 PM
jimbob200521's Avatar
Not without pictures I won't be!!
Glad to see you finally came to the dark side, I knew you'd come around
-Ryan
Old 11-11-2015, 06:51 PM
OK, OK I'll take a couple pics tomorrow. Now are you happy? I hate winter! Time to fill the hot tub.
Old 11-11-2015, 06:57 PM
twoton twoton is offline
OK, OK I'll take a couple pics tomorrow. Now are you happy? I hate winter! Time to fill the hot tube.
Glad someone's ready, I haven't even started and I'm a few degrees north of you. I'd fill my hot tube too if I had one, not sure what that is???
Old 11-11-2015, 07:01 PM
You guys are a riot, sorry I meant Hot Tub.
Old 11-12-2015, 04:15 PM
Ok Ryan, here are the pics as promised. Hope I don't need to use it but if we get anything worth plowing I'm ready. I hate snow.
Old 11-12-2015, 06:19 PM
That's more like it
Something I've always wondered with blades with that lift setup off the bucket: does that bucket hanging out there ever get in your way or block your view? And also, is there a benefit to going that route rather than taking the bucket itself off and getting a blade attachment?
-Ryan
Old 11-12-2015, 06:30 PM
Looks to me like the bucket is what lifts the blade. Never seen that kind of set up before until Sam "should have moved to Florida" Mac posted it last year
Old 11-12-2015, 06:56 PM
Well here's the deal Bota get's over $1800.00 for a snow plow for a BX. I built this from an old Myer plow that was on a Ford F-150 for under $500.00. The loader is used for the lift and the bucket function circuit is used for the power angle. It takes about 5 minutes to mount it to the tractor, 1 pin, 2 quick connect hoses and the lift chain. Vision is not a problem at all, I can see the corners of the plow with no problem. This is the 3rd plow of this design that I have done. I sold the others. 1st one was to an owner of a BX in CT, second one went with the BX2200 that I had before the BX2660. If you have a tractor with a loader this is an easy way to go. This pic is pushing snow up into a pile when I lived in CT, we got 112" of snow that year, this was just an early storm. This setup allows you to raise the blade much higher that anything offered by the factory. Back to Cub Cadet stuff now. It's cocktail hour, gotta go.
Old 11-12-2015, 10:34 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Im with you Sam.... I hate winter!!
But fortunately in South Ga we don't have much winter! No snow at all!
I like the plow on the BX!!
Jay
Proud owner of the following:
