Old 11-12-2015, 07:32 PM
TN_Explorer TN_Explorer is offline
Default Moving the carport
So I pulled the plug and relocated my 18X20 aluminum carport today. I had scoured the net and found all kinds of thoughts on how to do it -- almost made me give up before I started. But I have a secret weapon - a Cub Cadet 782!
Initially I was concerned about twisting or racking the carport and thought about bracing it, but then I decided if I was careful I could pull it without damage. I set a couple of pulleys straight out and in line with each side, and using a long rope hooked to the Cub I pulled toward the carport. The ropes pulled the carport nice and straight, and since I was pointed toward the carport, I had a clear view of what was happening. Taking it easy and stopping for breaks every little bit, it took me about two hours by myself to remove the anchors, move the carport and reset the anchors. I love my 782!!
Old 11-12-2015, 07:35 PM
MWShaw's Avatar
MWShaw MWShaw is offline
Nice work.
Old 11-12-2015, 08:31 PM
mortten mortten is offline
My neighbor has a canvass covered car port. I was out in the back yard and watched the wind lift it about 15 feet in the air and move it to the woods for him. The wind didn't move it as carefully as you did.
Old 11-12-2015, 09:07 PM
Nice job for a 1 man show!! Mine needs moved, too when I get a chance, but mine will need over about 7' sideways. I was going to recommend sleepers, but I saw that you already thought of that. Archimedes would be proud of you.
Old 11-12-2015, 09:30 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Very nice work!! Great idea with the ropes and pulleys!!
Jay
Proud owner of the following:
Old 11-13-2015, 07:03 AM
Well done!
