Old 11-13-2015, 08:14 PM
Trekrider60's Avatar
Trekrider60 Trekrider60 is offline
Default K321 can only idle
Hi guys; I need some help. I ran out of gas the last time I used my 149. I refueled, but it wouldn't start. Pushed it to the garage and it sat overnight. Fired right up the next morning and idled great. I didn't give it any throttle since it started and I didn't need to use it. Forward six weeks, I started it up and it would idle, but try to give it some throttle and it just missed and shook. I have had the carb cleaned out in an acid bath, changed the fuel filter, checked the points, put in a new spark plug. It still idles, but it will die if I increase the throttle. Any ideas on what to do next?
Gene
149 w/Front Blade
Old 11-13-2015, 08:23 PM
will it throttle up with the choke on?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-13-2015, 08:24 PM
My best guess would be a clogged passage in the carb. If something is lodged, the acid bath you used wouldn't clear it out.
Old 11-13-2015, 08:29 PM
budscub's Avatar
budscub budscub is offline
Default Maybe fuel tank strainer
Just a thought being this happened after running the tank dry, May have gotten something in your fuel tank outlet
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 11-13-2015, 08:36 PM
No it won't throttle up with the choke pulled up olds45512. It just dies out.
Jeff, I sprayed carb cleaner through each passageway I could find and all seemed open. That's when I took it in to the tractor repair shop that I get parts from. That's were they put it in the acid bath. Any suggestions on cleaning out the passageways?
Gene
149 w/Front Blade
Old 11-13-2015, 08:40 PM
Bud, gas runs out of the tank line in a full stream.
Gene
149 w/Front Blade
Old 11-13-2015, 08:44 PM
If you are completely sure all the carb passages are clean, then check the adjustment screws themselves. There are passages in them too.
BEFORE you remove the screws to check, count the turns in to lightly touching bottom so you can return them to the prior setting. Post how many turns both of the screws require ( just in case the setting is way off )
Old 11-13-2015, 08:50 PM
I've had the idle and main screws out three times. Set them to the K321 settings listed in the Kohler manual. I got the idle screw set, but changing the main doesn't make any difference at idle.
Gene
149 w/Front Blade
Old 11-13-2015, 08:53 PM
bad coil or condenser....
Up to 534 and counting...
Old 11-13-2015, 08:59 PM
I have no idea how old the coil is; it was on the 149 when I got it last Jan. The condenser is just a year old with about 10 hrs total use. I wondered about the coil, but didn't know if it would cause this problem.
Gene
149 w/Front Blade
