Old 11-16-2015, 05:19 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Build Date Revisited
Is there a way to determine when my 1772 was built by using the serial number? There is no build date sticker on the frame. Is there an alternate spot where a duplicate sticker/code may have been placed? Perhaps someone with a serial number close to mine could narrow the build date.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 11-16-2015, 06:21 PM
CubDieselFan's Avatar
What is your serial number? I will check mine tonight.
Old 11-16-2015, 10:50 PM
My serial number is 788373. What I can read of the build tag is ?039G. I might be able to see it better in the daytime.
Old 11-16-2015, 11:00 PM
FrankF3's Avatar
My serial number is 787784. Hopefully someone has one that is close with a build date tag.
Old 11-16-2015, 11:56 PM
Frank, the one on CL that is for sale is 786977 and has a date code of C139G. I'll look at my others tomorrow and see what I can find.
Old 11-17-2015, 10:43 AM
FrankF3's Avatar
That's only 807 away from mine. Would that be a couple days of production?
Old 11-17-2015, 02:03 PM
If you knew how many cubs were made it 1989 you could take that number and devide it by the number of work days in the year which would give you a rough daily output, once you have that number it wouldn't be to hard to figure out what day it was made give or take a few days for variation in output.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2015, 09:18 PM
Okay here are mine.
Ser# Date Code
786906 C099G
787240 MIA
791627 J069G
Old 11-18-2015, 04:12 PM
FrankF3's Avatar
Well, that gets me a little closer to decoding my build date. Using the examples from this thread I can honestly say I have ???9G. With a few more examples maybe I can narrow it down. The first digit with the current info I have can be D,E,F,G,H or I. The numbers of tractors between the examples given of 786977 3/13/1989 and 791627 10/6/1989 is 4650 machines being built over a span of 207 days, or 175 days using a 6-day work week or 146 days with a 5-day work week.
Old 11-18-2015, 11:44 PM
FrankF3's Avatar
Does anyone know how serial number were assigned at Cub Cadet? For example, I have paperwork for an 1872 that I purchased for my father that has a serial number of 785840 that was purchased on 4/17/1989. I want to head over to my fathers over the next couple of days to get his build date. The number of the 1872 is right in neighborhood of my 1772 as well. I think they must have run multiple models one after the other or in short runs, while giving the next available serial number the next machine on the line. I could be wrong though.
