Old 11-22-2015, 06:17 PM
twoton twoton is offline
Default Messin around
Messin around with a couple of the cubs today preparing for the ... inevitable.. and got the new to me snow thrower hung on the 1650. Gots some sort of heat shield around the discharge chute. Lift bracket looks to have been "modified" by a PO. Thought that should have been 90 degrees to the lower lift arm. Thought I'd cut it off and re weld it back in position so the supplied connecting rod would work, but,.. found another rod in my stack of stuff that would work as is. Heat shield would not allow the chute to rotate so I had to modify accordingly... Top of heat shield interferes with opening the hood??? Maybe I should just cut the thing off??? (the heat shield that is)
Old 11-22-2015, 06:31 PM
That is definitely a PO mod.....cut if free! Looks like a real powerhouse for the snow you have there. It's kinda fun just messin' around, just don't go "messin' with the man!"
Old 11-22-2015, 07:52 PM
Terry C's Avatar
Terry C Terry C is offline
That's a good looking snow removal crew there! More pics please!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-23-2015, 05:35 AM
Yeah Terry, wanted to bring the 1450 home from work for a group photo but then got to thinkin, "then the wife will know I got 3, oh, can't forget the other 1200 I got for parts, I mean 4. well there's hers too, I mean 5, better stop now."
Old 11-23-2015, 12:22 PM
Terry C's Avatar
Yeah I hear ya, be careful with letting her know the exact number!
Terry
3225
Old 11-23-2015, 02:04 PM
Yeah Cub Cadet 123, I’m hoping it will be a real power house. Last winter my neighbor built a three wheeled, v bladed, strobe light flashing snow plowing monster so I really got to show him who da man is this year! Unfortunately for him his 5’7”, 147 lb frame didn’t provide enough ballast to do much good with it. Even with loaded tires and all the steel weights he could wire onto the thing he spent most of his time spinning tires so I think I got a chance.
Regarding the heat shield, I think it’s to help prevent the exhaust from icing up the chute. Reluctant to cut it off but.., would really like for the hood to open!
Old 11-23-2015, 02:36 PM
Berwil's Avatar
Berwil Berwil is offline
What does the inside surface of the chute feel like. If it is rough/rusty, that is the first factor as far as icing/blockage. Get the rust off and paint it with high gloss or graphite paint. The QL exhaust is the second factor to icing. It looks like you have an elbow on your exhaust pipe? If so, that should be all you need. I have a 45 degree elbow that I put on my exhaust when I hook up the snow thrower on my 1450. Since installing the elbow and painting the chute, my icing problems went away. You can ditch the heat shield.
Bill
Old 11-23-2015, 10:23 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Absolutely, I have a similar setup with a 1450. The exhaust doesn't bother none, look at it like an automatic defrost cycle!
Cool rig btw, you'll love it!
1- 1200 in pieces
1- 1864 in pieces
Old 11-24-2015, 03:26 AM
Yeah, thanks guys, it's coming off.
Old 12-20-2015, 05:21 PM
Well I think I'm ready, almost. Removed the shield, got a speed up pulley, got a new belt, added some extra lighting, checked to make sure that the thrower came with the proper right angle gear box;
http://www.onlycubcadets.net/forum/s...ead.php?t=7866
