Old 11-25-2015, 02:10 PM
gkingbing gkingbing is offline
Default CC 1541 Blade
Does anyone know if a blade that was on a 1641 will fit on a 1541? I read something about requiring a rock bracket! Is that a must if this blade does not have one? Are there any sites that display how to mount a plow on a 1541? Thanks and Happy Thanksgiving. :Thanks
Old 11-25-2015, 03:33 PM
Plow should mount OK but you'll need the connection parts for the lift like on a 782.
I'm moving this thread to the implements section.
Lift rod should attach to the lift on the right hand side of the frame. You should have something that looks like this pic. Hook up the lift rod in one of the holes shown here in red. Not sure if you have 2 holes on a 1541. Pic is from an earlier model. You may also need to play with the length of the lift rod.
Old 12-15-2015, 10:58 AM
Default CC 1541 Plow
Thanks for the great pic. Got the blade home, painted and mounted. Had a lot of surface rust to deal with. I used Rustoleum Rust Reformer after sanding to see if its any good under primer and top coat. Time will tell. Was hoping that the blade would lift higher to push back snow banks. Oh well, will just have to attach them at full throttle.
Old 01-07-2016, 07:25 AM
Tankman's Avatar
Tankman Tankman is offline
On my 1641 I had to extend the lift rod approx. 2". Added the casting for the lift, $50 new.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 01-27-2016, 10:35 AM
Default Blade lift CC 1541
Great information...The blade is a done deal. I added teflon to the cutting edge and power angle. The lift distance on the blade is only around 3 inches. Has anyone found a way to increase the lift distance? A higher blade would be more effective in pushing back higher snow banks, if we ever get snow here... : )
Old 01-27-2016, 11:11 PM
PeterJ PeterJ is offline
The lift arm on the tractor would have to be longer or/and the actuator arm on the blade would have to be shorter. That would increase the travel of the blade.
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
