Pulled the 1512 into the garage for a once over before putting the snowplow on for the winter. Wanted to change transmission fluid and grease the machine up. Noticed the rear axle end seals starting to leak, carrier seals little leak and one of the rubber grommets on the gas tank leaking diesel. Pulled everything apart, made a list of parts and placed an order online. Looked through my cub cadet manual and couldn't find torque specs for the rear cover bolts.
Found the basic chart in the front of the book showing 21 ft lbs for a 3/8 inch bolt. Any thoughts? Also any thoughts how long the axles end seals last? I looked over my records and it seems I replaced them 10 years /500 hrs ago. Is that good or bad? Thanks |
Just use a 3/8 ratchet and tighten them until there tight, torqueing them isn't necessary.
30 foot-pounds will be sufficient for the axle tubes.
The rear PTO installation instructions take some rear cover bolts off, remove the hitch and then you have to re-attach while tightening the bolts to 30 Ft/lbs. I would think they would all be the same torque.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
