Old 12-01-2015, 05:25 PM
rdehli rdehli is offline
Default 1812 hyd line
In need of a hyd line 727-3016 goes from hydro to hyd valve. number 14 in the pic Iam located in Waukon, Iowa thanks much
Old 12-01-2015, 09:02 PM
bocephus1991's Avatar
I'd take it to your local napa and have them make a hydraulic hose.
Brian
Old 12-01-2015, 10:02 PM
A viable option. No bad points other than just tying it up out of the way at the rear where the fan is.
Old 12-01-2015, 10:29 PM
Did that for a hyd hose on a 1486 once. Getting the old metal line out was a sob!!!
Brian
Old 12-01-2015, 11:00 PM
Isn't that the return line with a 37* flare? Can it be spliced or straightened out? If not, you need one from a dual spool machine because the single spool comes in the bottom of the valve.
Old 12-01-2015, 11:34 PM
45° flare will seal fine.
Old 12-02-2015, 05:30 AM
MWShaw's Avatar
MWShaw MWShaw is offline
I have a hydraulic cylinder repair shop near me, that makes hoses as well? Check your yellow pages.
Old 12-02-2015, 07:19 AM
cubs-n-bxrs's Avatar
I made mine on my 1450 with 3/8th brake tubing and a flaring tool.
Old 12-02-2015, 11:40 AM
All my local shops JD, NAPA, Machine shops etc. want to make me a hose I would really like to keep it as original as possible. might go with the brake line etc. got a buddy checking the parts depot.
Old 12-02-2015, 12:57 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
wish I was closer I could bend you one. if there a hydraulic shop near you they should be able to make you one. if they make you a metal one have them make it in stainless last for ever not that much more expansive here in buffalo anyway.
