Old 12-11-2015, 11:49 PM
bocephus1991's Avatar
Default Hytran substitute??
https://www.shcsupply.com/products/5...%7C147067.html
Anyone know anything about this oil from lube king? Supposed to be a hytran substitute. Or is this like the 303 hyd oil from orscehlens?
Brian
Old 12-12-2015, 01:13 AM
cubby102's Avatar
cubby102 cubby102 is offline
Pretty much what I use. No issues at all
Old 12-12-2015, 06:24 AM
It's close but not the real thing.
Old 12-12-2015, 08:01 AM
cubs-n-bxrs's Avatar
Oh no not the dreaded Hy-Tran debate.
Old 12-12-2015, 09:18 AM
The only thing I'll say is,
do be aware some oil has a higher viscosity and will give you problems in cold temps, like slow or no starting and pump cavitation till really warm.
303 from tractor supply did not like to flow well @ colder temps for me.
Old 12-12-2015, 09:54 AM
Whatever fluid you choose to use be sure it says non foaming, if the fluid foams when hot it will put air in the system and cause the pump to over heat. I run hydraulic/trans fluid from Brad Penn, its what we use in the Ford select o speeds.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-12-2015, 12:36 PM
gdheck's Avatar
gdheck gdheck is offline
I stand firmly in the "there is no substitute" category. I figure the price is just part of the cost of having these toys.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-12-2015, 03:58 PM
jimbob200521's Avatar
I always love reading through these hytran "debate" threads; always get a kick out of em
-Ryan
Old 12-12-2015, 06:07 PM
I've gotten to the point that I don't even comment anymore. Read the manual.
Old 12-12-2015, 06:53 PM
Merk Merk is offline
Same here
Project Uncle Dick
Cub Cadet 70
