Old 12-14-2015, 02:05 PM
Default Haban 402d on a wide frame.
As I understand it the 402d is for a narrow frame cub but Id like to put it on my 108 and I've read on this forum and others that it will fit without any mods but just wanted to confirm.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-14-2015, 02:51 PM
gdheck's Avatar
gdheck gdheck is offline
I had one on my 1450 for a while, although I never hooked the belt up. I think the only thing that needs changed is the position of the drive pulley on the shaft. Maybe you'll need a different belt. It didn't look like much was needed to make it work.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-14-2015, 05:17 PM
mrmiller mrmiller is offline
I believe the 402D fits both narrow and wide frames with some minor adjustments.
Old 12-14-2015, 07:35 PM
I believe the guys are right, I had mine on a 128 and changed it to a 106, the best I remember, I only had to change the location of the front pulley.
Lew will probably be along in a little bit and tell us all what the real deal is.
Old 12-14-2015, 07:53 PM
I put a 402E on a Cyclops, just had to mod up a mule drive to make it fit.
Old 12-14-2015, 08:10 PM
what they said....When you move the pulley to accommodate the difference in the NF to WF you may need spacers to keep the jack-shaft true...
Look at the parts,move pulley, it will be clear as a bell
Up to 530 and counting...
Old 12-14-2015, 08:21 PM
thanks for the info guys, hopefully sometime soon it can get it fitted and take it for a test run. anybody know where to get a reproduction decal set?
Pap's 100
Restored 108
1211 Dual Stick
1050
