Old 12-23-2015, 07:43 AM
amflyer amflyer is offline
Default Question on Snowblower Fitment
I am looking at a 190-451-100 2 stage snowblower. It is being offered to me by a friend for no cost. I have a 1450 with a freshly rebuilt motor that runs great. Can I fit this blower on my 1450 and can I run this blower with no issues? It looks like it will fit the tractor but not sure of the operation of this unit.
R Leppo
Old 12-23-2015, 10:05 AM
yeeter yeeter is offline
A great price. That blower will throw snow like crazy (I have a 450, which is similar).
I believe it will mount. You may need to change the pulley to get the speed matched correctly.
Its a heavy blower so add weight in the rear.
Is a 1450 enough hp? Iffy, but if I were given it for free and had strong running 1450 I would try it. (blowers take lots of HP so it will tax the engine)
The alternative is to trade to someone for a QA42A, which is a single stage 'thrower'. They dont work as well, but do work (difft opinions on this). You would likely gain some $$ in the trade, if that matters. I would try the 451 first.
$.02 Others will give much better advice.
Old 12-23-2015, 06:21 PM
451 is meant for a 6" PTO clutch. By the time you get the pulley's right, you will lose all your torque. It was never made to fit a QL. Better pass. That or take it and trade it for a QA42A. If it was a 450.... you may be able to make it work...... but 14hp will struggle to run it.
Old 12-24-2015, 07:00 AM
What size pulley is on the 14 horse quiet line pto?
Old 12-24-2015, 08:54 AM
What size pulley is on the 14 horse quiet line PTO?
4.50" OD Diameter
Old 12-26-2015, 05:43 PM
Happened across this thread, a 450 on a 1450:
http://www.onlycubcadets.net/forum/s...ad.php?t=28272
Old 12-26-2015, 06:36 PM
450 would likely work. 451..... not so much.
He never said how it worked out......
Old 12-30-2015, 03:59 PM
OldSkull's Avatar
OldSkull OldSkull is offline
The best fit for a QL is a 2 stage 364 snowblower(190(5)-364-100)
I spend 2 years to find one close enough to my place with the wrong PTO kit and I found 2 others for sale since I purchase mine a month ago.
Now I found a third one on a Kohler Magnum powered Cub cadet almost ready for action, wish me good luck
PS: I need a bigger garage...
Gilles.
1963 100 (red)/in storage
