Old 12-29-2015, 09:35 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default Removing an exhaust elbow
What's best way to remove exhaust elbow, without messing up block, I sure it is posted on here some where, but short on time this morning
Donny
Old 12-29-2015, 11:28 AM
You may have to heat it up red hot with a torch, been there, done that...
Old 12-29-2015, 11:46 AM
Some have had luck with heat, or doing it cold with BFH and a pipe wrench. I just did one and nothing worked. Had to saw it off flush then use hacksaw blade and cut 3 slits inside of it then use chisel to break pieces off, obviously being careful of threads. Got idea from member triplethreat
