Old 01-01-2016, 02:08 PM
Default Loader Question
Picked up a WH tractor with a johnson model 10 loader on it with intentions to move the loader to one of my 149's.
It is low on fluid and want to make sure I can use Hy-Tran to top it off.
Thanks for the help!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 01-01-2016, 02:24 PM
What is low on fluid, the loader, the WH or the 149?
Old 01-01-2016, 03:41 PM
gt383mag's Avatar
gt383mag gt383mag is offline
i just use light hydraulic fluid on my kwik-way if thats what you mean but in winter that seems thick could use trans fluid in winter hy-tran would be kind of expensive in the loader
Old 01-01-2016, 09:34 PM
Sorry, yes the loader has a tiny leak.
Thanks, RAndy
1 100's
2 149's
1 73
1 2182
Old 01-01-2016, 09:45 PM
Since I don't know exactly what has been used in it, should I drain the old and put all new? First loader and want to make sure I use the right stuff.
Randy
1 100's
2 149's
1 73
1 2182
Old 01-02-2016, 08:42 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Randy
Since your loader is plumbed with it's own pump and reservoir, it probably uses standard hydraulic fluid (like AW46), not trans/hydraulic fluid like Hytrans but I even seen some Hyster 5 tons lifter been fill with Canola oil because it was free so...
If I was you, I drain the system, repair the leak , install a inline filter (If you don't already have one) and fill back the system with standard or synthetic hydraulic fluid (Budget wise)
Gilles.
1963 100 (red)/in storage
Old 01-02-2016, 09:51 AM
What OldSkull said!
Old 01-02-2016, 10:37 AM
All good advice, one thing I might add is TSC sells a 505 fluid. it is pretty thick and gives problems in cooler temps so I would stick with a lighter weight fluid.
good luck!
Old 01-02-2016, 11:05 AM
Jumper Jumper is offline
Randy Littrell, this is from the Johnson Loader manual...........
Old 01-02-2016, 11:38 AM
Thank you all for the help, I believe a can get it from here now!!
Randy
1 100's
2 149's
1 73
1 2182
