Old 01-09-2016, 11:24 PM
Sprint60's Avatar
Sprint60 Sprint60 is offline
Default Identify Narrow Frame Mower Deck
OK, I give, I've been trying to locate parts sources and instructions for the deck mounted on one of the 147s. The tag over the discharge reads 482 U1111. Measures just shy of 48-inches outer tip to tip and just shy of 50-inches edge to edge.
Needs an anti-scalp front roller, new gauge wheels and bolts and I'd like to have a spare set of blades. The spindles feel good and the belt is like new.
(The manuals section gives me a permission denied.)
Here's some snaps:
Old 01-10-2016, 12:04 AM
That's a 48" cast center deck. Possibly built between 1968 and 1971.
You may be able to download this PDF, it has a lot of information in it.
http://www.onlycubcadets.net/forum/s...ad.php?t=24721
It has also been difficult for me to find information on mower decks based on the ID tags. The first two numbers on the tags are the deck size.
You must have done something REALLY bad if the manuals section gives you a permission denied!
Old 01-10-2016, 12:17 AM
Sprint60's Avatar
Thanks for the assist! Couldn't find anything that matches on parts tree. Yeah, I've been a baaad boy. :-)
Old 01-10-2016, 10:52 AM
IHinIN IHinIN is offline
I believe there were 3 versions of that deck. The first version had cast spindle housings with tapered roller bearings. The later versions used the stamped housings with water pump style bearings. There were also differences in the skids (round rod vs half round) and the rear quick attach brackets that hold the spring loaded pins.
Old 01-10-2016, 04:51 PM
Another vote for 48". No discharge guard on yours though.
Old 01-12-2016, 02:36 PM
Ash_129 Ash_129 is offline
Yes, a 48" deck/cut there you have there. It looks like it is probably the 2nd version of that deck. (4-bolt outer pulley covers - from what I can see of the holes, center deck belt/blade drive pulley is the same size as the top/driven pulley, and has quick-connect rear hangers.)
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
