Old 01-14-2016, 02:02 PM
biglefty's Avatar
biglefty biglefty is offline
Default 44C deck spindle
What would be the easiest way to get this pulley off the spindle?
Old 01-14-2016, 02:11 PM
j4c11's Avatar
j4c11 j4c11 is offline
Hold the pulley with a box wrench and take the nut off with an impact wrench. Then it should just slide off the shaft, may need a little encouragement. Don't lose the square key.
Old 01-14-2016, 02:36 PM
biglefty's Avatar
Ok Thanks, I was afraid you might say that will need to pick up a bigger wrench. How would you get a box wrench on the center one?
Old 01-14-2016, 02:43 PM
j4c11's Avatar
I don't recall mine looking like that, but it's been a while. What you could do is put two nuts on the spindle side (the ones that tighten against the the mower blade),hold the first one with a box wrench, remove the pulley nut on the other side with an impact. The second nut should prevent the first one from moving.
Old 01-14-2016, 02:52 PM
biglefty's Avatar
Ok thanks will give that a try
Old 01-14-2016, 03:17 PM
Yeah, right!!
