Old 01-16-2016, 09:29 PM
southeastern southeastern is offline
Default Tech. Manual
I own a GT3100, SER.# 1K146G30026, DOM 11/2006, I'm looking for a tech./ service manual for this tractor, I have one but its for an older 3000 series and some things are a little different like the key switch terminal designation, any help with this would be appreciated. Thank's
Old 01-16-2016, 09:35 PM
I have not seen one yet and I have the older manual that isn't much help on the newer machines. What problem are you having?
Old 01-16-2016, 09:57 PM
I saw a post from gt383mag about a tractor not wanting to shut off when you turn the key off someone had suggested checking the ground wire for the mags. so I started to look at this today and I checked the key switch because that's where the ground comes from to kill the motor. When I looked at the switches in the manual I have it was clear that the key switches they were showing did not match up with mine, so with an ohm meter I figured it out what terminal goes to what, but I would like to get the correct manual for my tractor.
