Old 01-22-2016, 01:32 PM
cadzag72 cadzag72 is offline
Default NF Thrower belt size?
Hi everybody! so I want to pick up a spare belt or 2 for my 125 with a qa42a, but my old belt the numbers are worn off and the cardboard I saved got eaten by mice. anyone got the right size? I usually grab my belts from NAPA.
Ian
Old 01-22-2016, 01:47 PM
mortten mortten is offline
The Cub number is IH-487043-R1. It is 3/8" X 28" so a 3L280 would probably work.
Edit- My mistake. A QA-42A uses an IH-55053-C1 which is 15/32" X 30". That would be a 4L300. The other belt would be for a QA-42 thrower.
Old 01-22-2016, 08:58 PM
Many thanks! That sounded familiar, picked one up on the way home and looks just right. This time I'll put the number somewhere mice can't get to it! And maybe I'll get a cat.
Ian
Old 01-24-2016, 02:39 PM
Magnum Magnum is offline
Is it the same belt for a 36 and a 42?
Old 01-24-2016, 08:16 PM
It should be the same for the 36a and the 42a, the mounting hardware and gearbox is all the same. Only difference is the width of the blower, and length of the auger driveshaft and chain cover.
Ian
