Old 01-24-2016, 09:29 AM
adamo adamo is offline
Question The Haunted 129 -_-
In 1973, my grandfather purchased brand new his 129. It was his workhorse on his home in Pennsylvania for 15 years. He was a tough old man, WW2 POW (Battle of the Bulge), purple heart recipient, however he was kind to me. He had pictures of me on it with him driving around the yard. After some time something happened with the 129 and he through a tarp over it and purchased a red cub. About 20 years later, I purchased my home in MA and my grandfather decided to give me his old 129. He brought it to his local cub repair shop and had the engine rebuilt and had it purring for me and brought it up to MA for me. I am not very mechanical and I have tried to maintain it while using it as my workhorse. My grandfather has since passed away from Alzheimers. After he passed, I have had issue after issue with the cub. Again, I know, its a 42 year old tractor. But I at this point I can't explain what is going on. Most recently I am getting no crank when I turn the key, just a single click. I have replaced the starter generator, the solenoid, the voltage regulator and the battery. I have wire brushed battery terminals and ground to frame from the battery. I have confirmed that I have voltage to the starter generator when I turn the key. I also confirmed that the new starter generator does spin after disconnecting from the cub and using jumper cables connecting the positive leads. My lights work as well. I've been searching for days now you tube help videos, wiring diagrams and electrical trouble shooting tips to no avail. So I signed up for this page. My wife wants me to get rid of it. She thinks it's cursed. I'm not there yet and don't think I will ever be. Any suggestions?
Old 01-24-2016, 09:36 AM
budscub's Avatar
budscub budscub is offline
Default Welcome to OCC
There will very knowledgeable folks along shortly to help you sort this out. You have come to the right place.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 01-24-2016, 09:38 AM
How did you check to make sure your getting power to the s/g? The s/g needs both positive and negative to turn so if you really do have positive at the s/g then it must be a ground issue, are you testing with a test light or a volt meter?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-24-2016, 09:39 AM
Bob95065 Bob95065 is offline
ACR not working? If there is a problem with the ACR the S/G may not be able to turn over the motor.
Old 01-24-2016, 09:41 AM
Yes I used a voltage meter. I used the same meter to confirm the solenoid is functioning when I turn the key.
Old 01-24-2016, 09:43 AM
Hi! What is the ACR? I'm sorry, just not super knowledgeable with this stuff.
Old 01-24-2016, 09:45 AM
Yes used the multi-meter and I did use the negative on the separate battery and attached the ground on the starter generator and the hot on the post.
Old 01-24-2016, 09:47 AM
Acr stands for auto compression release, the camshaft has the acr built into it and it makes the engine turn over easier. If you take the belt off the s/g does it spin when you hit the key? If it does you may have an acr issue but if it still doesn't spin then the issue is elsewhere.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-24-2016, 09:48 AM
Oh thanks! Yes it spins the motor. I left the starter generator pulley attached but disconnected the electrical and then used a battery to jump it. It spun the motor.
Old 01-24-2016, 09:54 AM
Ok then I doubt its the acr. Like I said if you really have positive at the s/g it must be a ground issue, as a quick test to confirm you can hook a jumper cable up to the negative terminal on the batt and hook the other end to the body of the s/g and if it turns when you hit the key then you know you have a ground issue.
Pap's 100
Restored 108
1211 Dual Stick
1050
Tags
129, electrical probs, no crank
