Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 01-26-2016, 05:29 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Block work??
Hey guys, I'm rebuild a k301. I just completed the manual resurfacing of the head to get it dead flat. What I just discovered is the block seems to be warped, I assume this is because the engine was ran hot quite a few times prior to my a quiting it. I know a couple of you are expert machinists. Before I get stupid and take the side grinder to it, is there a way to flatten the block surface. With tools I have at home?; I can't afford a machine shop right now..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 01-26-2016, 07:38 AM
I just did mine using the glass and sandpaper trick-good way to build up the forearms, that block is heavy.
Old 01-26-2016, 09:16 AM
How did you determine the block is warped? I'm sure you could straighten it up the same way as the head but its gonna take a while since its cast iron.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-26-2016, 10:22 AM
I would be Leary working it back forth on a piece of glass !!
maybe a surface plate but your still going to get some rocking.
So much easier to put it on a B'port and take a small fly cut off the surface.
taking as little as it takes to make it flat, the littler the better.
Like others, how do you know it is not reasonably flat?
only real way is indicate it, or use a surface plate.
Old 01-26-2016, 10:57 AM
Terry C's Avatar
Terry C Terry C is offline
Now that your head is reasonably flat, set the head on the block and just start
a couple of bolts to make sure it's sitting in the right place. Take a .003 or so
feeler guage and find where the high and low parts are. Then take a large file
and start hitting the high spots. Be careful, I am always leary of telling people things that require some touch cause I don't know their ability
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-26-2016, 11:36 AM
Mine had been run a while with blown gasket, checked using a straight edge.'Yeah the block tries to rock but some oil on the paper helps a lot.
Old 01-26-2016, 12:25 PM
john hall's Avatar
If you have a large honing stone I would run that over the block to knock off any "blisters" around the holes. Then set the now polished and presumably flat head on the block and check with feeler gauges as already suggested. Then if it is not flat you can figure out what to do next.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-26-2016, 05:51 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
a straight edge and a feeler gauge is what you need. are you boring it? grinding valves? just take it in and do right. the end result is worth it
