Old 02-02-2016, 09:32 AM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Default To buy another . . .
I'm thinking about getting another Cub. (surprise surprise) I'd like an Original. But if the right deal comes along, I'm open to other models. I saw an "O" and a 105. The 105 has a 12 horse engine. It should be a 10, right? And the "O" was repainted, but not the prettiest job. What are some things you all think I should look out for or stay away from?
Old 02-02-2016, 09:46 AM
If you're into a little road trip, I have a nice running 104 with a plow and 48" deck.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-02-2016, 10:13 AM
Jeff122's Avatar
Thanks for the offer. That would be an all day trip for me. I am at the beginning stage of looking. My first preference is an "O". I have a few implements for my 122. The 125 and the "O" I found are only a couple of hours away.
Old 02-02-2016, 12:54 PM
It really depends on what you want to do with your second Cub.
Originals are great fun to use/ride around on and I really like the way they look. They can be weighted but are a little lighter than the models that follow. They also wont cut thick heavy overgrown grass like some of the higher HP machines but will do a good job if you can keep up like you should.
One thing to keep in mind is, Originals are somewhat different than the models that followed. After the introduction of the 70/100 series, all of the IH built Cub Cadets are basically the same, different series tractors look a little different, but they are all Kohler powered, the trans-axles and drive lines were pretty-much the same and with the exception of the hydro/gear drive systems you won't find a lot of differences in the different series tractors. IH got it right and they stuck with it.
Old 02-02-2016, 01:07 PM
Jeff122's Avatar
I'm looking to restore an "O" and maybe some light yard work. No mowing or dirt plowing. I'll save that type of work or "playing" for the 122. Mainly I think they look pretty cool.
Old 02-03-2016, 08:03 PM
IMO quality over quantity, and hold out for what you really want.
Old 02-04-2016, 07:04 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 02-04-2016, 10:15 AM
Jeff122's Avatar
Without a doubt, Dan. I've seen a couple of junkers with missing pieces. I can be patient. Will probably look into getting a wide frame as well. Just need to make more room in my garage. Time to sell the pony.
Old 02-04-2016, 09:08 PM
bocephus1991's Avatar
I'm think if I found an O for cheap I'd buy one. Kinda getting interested in one.
Brian
Old 02-05-2016, 01:33 AM
OldSchool81's Avatar
OldSchool81 OldSchool81 is offline
Sounds like an "O" is right up your alley. I had two of them for about a year
but grew tired and moved on. They are fun machines but just didn't suit my
needs.
