Old 02-03-2016, 04:28 PM
BThein's Avatar
BThein BThein is offline
Default Help with 982 Serial Number
I am looking at a new to me 982 project but have some questions that decoding the serial number would really help with.I read it as 2050595U687465 ,also I have a pic of the rear and I know my previous 982 with the cast one had a dip stick in the top cover this one has none at all.I'm thinking the aluminum one should still have the dipstick towards the rear.Thanks for any help with this some day I'm going to have to get the right books to have these things handy.
Bob
Old 02-03-2016, 05:05 PM
The aluminum rear ends with S/N: 720,000> had the dip stick. Prior to that serial number, they had none.
Old 02-03-2016, 05:10 PM
BThein's Avatar
Thanks Roland,good to know it's always hard to tell from pictures I really want to see it in person.
Bob
Old 02-03-2016, 05:53 PM
That is not an aluminum rear in the pic. This is an aluminum rear (with SGT braces).
Old 02-03-2016, 06:13 PM
aagitch's Avatar
aagitch aagitch is offline
I thought some of the cast rears for the early 982s had a dipstick because the 3pt hitch kept you from accessing the fill plug on the back cover.
Adrian
2072 (789513)
Old 02-03-2016, 06:26 PM
BThein's Avatar
Thanks Sam,I thought it looked like the cast one.Another 982 I had previous to this one did have the dipstick as aagitch was kind enough to show a picture of.I guess I'm asking could it still be correct without the dipstick in the top cover as this one has no three point.
Thanks all, Bob
Old 02-03-2016, 06:31 PM
Hard to say but if the pump input shaft is a 5/8" 9 spline at least it's for a Super. If the input shaft is a 5/8" round with a 1/4" hole for a spirol pin it's a GT pump. Also the shaft coming out of the back of the pump for a Super should be splined for the rear PTO.
Old 02-03-2016, 06:44 PM
Adrian is right and I stand corrected. I looked in the TC-193 Parts Manual - Section H, and a "foot note" says, there was a IH-144777-C2 Cover with Gage.
I learned something today.
Old 02-03-2016, 09:00 PM
ken746 ken746 is offline
The input and output are both splined on this pump.
Old 02-03-2016, 09:44 PM
john hall's Avatar
The dipstick on the earlier 982's has been discussed before, although it was quite a while back. They did have one, at least on mine a some other folks here. It is made very similar to the engine oil dipsticks on some IH tractors. It is a real pain to check the fluid level with one of them.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
