Go Back   Only Cub Cadets > Resources > Technical Library - Tractors
Closed Thread
Old 02-05-2016, 09:50 AM
twoton twoton is offline
Default Steering Wheel Removal
Today I made this clamp to use with the steering wheel puller that I already had. Got the ideas from here;
http://www.onlycubcadets.net/forum/s...93&postcount=1
http://www.onlycubcadets.net/forum/s...6&postcount=14
http://www.onlycubcadets.net/forum/s...66&postcount=2
The clamp started out as a 1 ¼” x 3” x 8” oak block. I used a 1 ½” hole saw to cut a hole vertically through the center of the block for the steering column, drilled two holes vertically through the block for the 3/8” x 5” galvanized carriage bolts with nuts and washers in locations that would work with my puller, and drilled two 5/16” holes horizontally through the block for the ¼” x 3 ½” carriage bolts with wing nuts and washers. I then ran the block through the table saw to make the two halves.
Worked well.
Closed Thread
