Old 02-07-2016, 10:59 AM
cdlong's Avatar
cdlong cdlong is offline
Default Qa-42
I picked up 2 of them yesterday. The bolt on snow thrower needs serious TLC. The quick-attach one has me puzzled. No ID tag that I can find & I can't see where the holes it would have been mounted with are filled in. Never saw an attachment with these type decals on it. I can't tell that it has been repainted. What's going on? Last picture, note the lift arm and the lever on the bottom bar in front of it. Is the lift arm correct or homemade. Any idea what the lever is for? It's on a threaded stud like the chute locks.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 02-07-2016, 11:38 AM
cdlong's Avatar
WOW, Did the Lord look out for me!!!! Really started looking at the 2 and the gear box mounts/ attachment arms are different. The nice one is a QA-42A.
HOORAH!
Papaw
Old 02-07-2016, 06:27 PM
cdlong's Avatar
It's mounted & operates on the 1450, but there was nothing quick about it. It seemed the bracket wasn't wide enough.
Papaw
Old 02-07-2016, 07:25 PM
cdlong's Avatar
I see in the manual that the wing nut is used to holf the lift arm bracket which keeps the hitch upright?
Papaw
Old 02-08-2016, 01:28 AM
Berwil's Avatar
Berwil Berwil is offline
I think the bracket on the lift arm is homemade. The thrower looks like it was mounted on a narrow frame, maybe it was easier for the PO to make that adapter then shorten the lift rod? The stud and wing nut (you called a lever) on the bottom arm is a "kickstand". If you take the upper link (above the lift arm in the last pic, first post) off at the tractor side and drop it down, it has a hole in the middle that goes on the stud. It holds the qa frame steady as you mount it.
Bill
Old 02-08-2016, 06:02 AM
cdlong's Avatar
Thanks Bill. Appreciate the info!
Papaw
Old 02-11-2016, 01:09 PM
creekcrawler creekcrawler is offline
Bill
Dang! Been staring at that "kick stand" bracket on my QA36 for years!
Never could figure out what it was for, thank you.
Old 02-12-2016, 02:04 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
X2!!!!
1- 1200 in pieces
1- 1864 in pieces
