Old 02-07-2016, 01:18 PM
Alpatrio Alpatrio is offline
Default Carb problems
I though this would be a better place to post this. I have a cub cadet 105 with issues i recently i had to fix the compression release mechanism in the motor to get it to start easier but now im having another problem. my carb is blowing air out when i put my hand in front of it i can feel it im not sure what might be causing this problem but my engine wont start. i took a syringe and stuck a little gas into the chamber through the spark plug whole the to se if it would run and it did until the gas burnt up. also if i spray gas into the air intake it will fire two until it burns that gas i checked to make sure there was fuel in the bowl and there is any ideas? im trying to get it ready to do lots of work this spring. thanks!
Old 02-07-2016, 02:04 PM
budscub's Avatar
budscub budscub is offline
Default quick thoughts
I presume you had the cam shaft out to repair the release mechanism.
If you have air blowing back out the carb, two things come to mind,
1) camshaft is out of time
2) intake valve is adjusted too tight.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 02-07-2016, 02:13 PM
bocephus1991's Avatar
I was think out of time. Check your valve adjustment first.
Brian
Old 02-07-2016, 02:53 PM
Will do thanks
Old 02-07-2016, 03:17 PM
Stewby Stewby is offline
Try this , pull air cleaner cover off and see if all three screws holding the back plate to the carb are there. If not we can guess where they are now... If they are there then the valves are sticking or way out of adjustment..
Old 02-07-2016, 10:10 PM
Default thanks
i appreciate the help everybody i adjusted the valves and she is running strong now
Tags
105, carb problum
