Old 02-21-2016, 09:52 AM
thadscub's Avatar
thadscub thadscub is offline
Default Cub Cadet 122 starter/generator
found problem never mind
Old 02-21-2016, 09:55 AM
My suggestion to you, is take that S/G to a reputable repair shop for an expert analysis. Repair as necessary.
Old 02-21-2016, 09:13 PM
thadscub's Avatar
Default not starter generator
hi guys i re tested the starter generator. And it is not a starter generator issue now it is electric issue. what should i start to checking have the battery on the charger.
Old 02-21-2016, 10:12 PM
Just curious....... How did you come to that conclusion?
Old 02-21-2016, 10:54 PM
Me too........
Old 02-22-2016, 12:27 AM
I'm a little confused now.
Does the S/G slow as it should when grounding the "f" terminal?
What is the original problem that you were investigating?
Old 02-22-2016, 07:38 AM
thadscub's Avatar
Yes the when grounding the f terminal it slows was the wire I was using and the battery
Old 02-22-2016, 08:29 AM
Re-phrase or better explain......
Old 02-22-2016, 08:43 AM
thadscub's Avatar
found problem
Old 02-22-2016, 09:19 AM
It sure would be a whole lot easier to read & understand what you are talking about, if you would use proper punctuation. Reading your posts three or four times trying to catch the meaning is frustrating.
