Old 03-01-2016, 08:36 PM
IHcubcadet1's Avatar
IHcubcadet1 IHcubcadet1 is offline
Default Leaky k161 gas tank....
I'm getting Really upset with my gas tank. I use jb weld.
First repair: leaked still
Second repair: leak
Third: NO leaks
Waited a couple months
LEAK.
my gas tank is falling apart. After the PO of my original set the tractor to rot outside without a hood.
It's now leaking where the threaded end is coming out where the glass bowl mounts. And around the threaded bolt.
Any suggestions or tips on repairing leaks on a k161 tank would help.
As once again, thank you all.
Old 03-01-2016, 08:52 PM
The threaded portion is soldered on. It has a square plate on it. You have to clean all.... and I mean ALL the gas out of the tank. You have to clean ALL the paint off and JB weld around that fitting. Then, you have to re-solder the fitting back on.
I suggest just buying another tank. If you've had that many leaks.... it's not worth the hassle.
Old 03-01-2016, 08:54 PM
If it's leaking at the nipple a new nipple may correct the problem.
It has been my experience that they normally leak where the insert is soldered to the tank.
Old 03-01-2016, 09:03 PM
I'll look for a new one. But I might take the time to fix the other one for extra. Thanks guys .
Old 03-01-2016, 09:13 PM
http://www.ebay.com/itm/Cub-Cadet-Ga...cAAOSwqYBWpj49
Look like one off an original? Doesn't even say in the ad....
Old 03-01-2016, 09:38 PM
Kohler made the gas tank. Not IH, so as long as it's a 7hp tank then it's correct. Looks right to me.....
