I'm in the process of refurbishing a 42" cast-end deck, and have a few questions about spindle bearing replacement.
First, how do you all remove the races from the bearing housing? The very helpful parts man at the local CC dealer suggested using a hammer & punch to beat them out, but I found it's impossible (for me) not to scar up the bore of the housing this way. Easily fixed with a Dremel, but I'd like to avoid having to do so. What's the preferred method? Second, can the bearing spacers be reused? The CC spindle bearing kit costs a LOT more than the bearings can be bought for separately. I plan to mic the new spacer I have & compare it to the old ones, but I want to find out what the prevailing wisdom on this is. Third, what's the preferred method for bearing race installation? Lyle (mentioned above) suggested grinding a discarded race slightly undersize, and using it and a hammer to set the new races. My thought was heating the housing in the oven and freezing the races, but I don't want the stench of old paint, grease, and rust filling my house. My next thought was taking the whole mess to a shop for installation, but I'd rather not pay someone else to so this. Thoughts? Any tips appreciated.
1965 122 with no bells or whistles, other than a spiffy restored 42" CI deck. |
Yes you can reuse the spacers. I put a bit of a chamfer on the end of a punch to help avoid scratches. After the first one, you can stick something down the bore to press the 2nd race out. A bearing driver and an arbor press or hydraulic press is the preferred method to install the races nice and straight. A socket and press or even a socket and hammer will do, but know that it isn't "the right way". A large vise will also work as a press in a pinch. Just put a piece of 1x4 or something on the jaws to protect the parts from the serrations on the jaws.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
I use a brass punch.
Thank you for the help!
I'll get a brass punch, reuse those spacers, and take the bearing assemblies to someone with a press & have the bearing races installed correctly. No sense going to all this trouble & skimping on such an important component.
You can put them in with the brass punch too. I freeze stuff like that alla time to save time and elbow grease.
Got it finally!
I decided to try a larger hammer with the same punch to remove the cups on the replacement center casting, and it worked great: instead of having to take a hard swing with my ball pein, all I had to do was drop the 3-pounder on the punch, which allowed me to hold the punch much more precisely and avoid damage to the housing bore. Quick, too. Yesterday, I stopped by a local tractor restoration shop to ask the owner if he could press the new bearing cups in. He says "You have a swinging press, right?", and tells me several times I could do it just as quick as he could, and I wouldn't have any problems at all. What the hell, why not? I found an appropriately-sized 3/4"-drive socket, grabbed my MAPP gas torch, and my favorite hammer. After heating the housing so I could get the bearing cup started, I was able to beat the cups home without much trouble. Yes! Now it's on to rust removal, paint, buying a bucketful of 1" carriage bolts, and putting it all back together. Thanks again for all the help.
