Dad has a 129 that developed a BAD oil leak last summer. He figured the flywheel crank seal had gone. I told him we'd get around to it. I kind of got the shop cleared out Saturday and he asked whats next? Told him we really should look at a couple pieces of our farm equipment and I wanted to change the tires on my Kawasaki Mule. I get home today and he's got his 122 and the 129 in the shop. The 122 only needed tinkering to get running, it hadn't been ran in a couple years, he already had that done. The 129 already had the hood and grill off and he was hard at it unhooking wires and cables. Guess there was no turning back at this point. He did all the wrench turning and then I sat the engine out for him. Nasty is not the word for the engine and chassis, like I said this oil leak was major. Pulled the flywheel to find the seal wasn't even sweating. The end plate on the motor however, well lets just say every bolt on it was loose. Got it all washed up and back in the shop. He had the gaskets and seal fortunately. I told him when we pulled the engine we would add a thrust bearing to the steering box so I took care of that. The front axle had way too much slop. I pulled it out and managed to get a 1/16 thick washer on the front side and made a new pivot pin, the old one was wore down about .020" The holes in the frame are worn pretty bad as well as the axle. Since this is just a repair and not a restoration the washer and new pivot pin will have to do. Lord knows the spindles and wheel bearings need help too, but that ain't happening. I did upgrade and put the new pivot pin in with a roll pin instead of a nail like the old one had.
![]() Hopefully we can get the motor back in tomorrow afternoon/night. Did I mention he's 86? Somedays he can get into more stuff than my teenager!
You helped your dad and fixed a cub today....that was a day well spent!!! What a nice job you did, too. However, the nail for the pin trick is every rednecks engineering improvement, so I am not for sure why you changed that.
Glad to hear your dad is 86 and enjoying his cub thanks to the attentive son he has. ![]() Cub Cadet 123
Time with your dad what more could you want.
Nice work john hall
Your Dad must still be getting around pretty good for 86
Looks good
I hope I can still work on my Cubs when I am 86.
Great job, John! I bet, you enjoy wrenching with your Dad.
Sounds like you both had fun! I'm interested to see the deck!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Great job and rime well spent!
