Old 03-23-2016, 09:30 AM
prlwpod prlwpod is offline
Default Need help with 38" deck spindle
Greetings- I picked up a 1320 Cub over the winter and the deck that came with it (model 331190) has one bad spindle. The original owner had removed it from the deck, and he did save all of the parts. What I'm trying to figure out is if this type of spindle can be rebuilt by just replacing the worn bearings. The shaft that rides in the bearings looks good, so I'm just trying to figure out what size and where to purchase the needed bearings. Any assistance will be greatly appreciated. As I'm not planning on keeping this Cub (I have three others), I'd like to do this as inexpensively as possible. Thank you, Paul, Providence
Old 03-23-2016, 10:57 AM
Nailhead Nailhead is offline
The bearings are Timken 11949, the races are Timken 11910, and they're easily obtainable online. You can buy a CC rebuild kit, but it's quite a bit more expensive and the bearings are made in China.
1965 122 with no bells or whistles, other than a spiffy restored 42" CI deck.
Old 03-24-2016, 07:40 AM
Default Fantastic!, Thank you so much.....
As I haven't dismantled the spindle yet and I haven't been able to find an exploded view diagram, let me venture a guess. Will I need two of each (Timken 11949, Timken 11910) to rebuild the spindle? Once again, thanks very much for your assistance, it is greatly appreciated. Paul, Providence.
Old 03-24-2016, 08:36 AM
Those are "Set 2" bearings that any auto parts store will have. O'Reilly Auto has a house brand for less than $5 each(both pieces). I've purchased these.
http://www.ebay.com/itm/Pack-of-10-T...item4188e2c262
Here are the seals you will need.
http://www.ebay.com/itm/6PK-CUB-CADE...item416d8b0f1e
Old 03-24-2016, 08:46 AM
Default Thanks for the links, what exactly am I.......
going to need to rebuild a single spindle? Two bearings, two races, and two seals? Those are great prices, so I'm guessing that they are not Timkens, probably Chinese manufacture? But if you've used them and can vouch for their quality, I'm in for sure. Thanks again, Paul
