Old 04-02-2016, 08:13 PM
redneckarchery redneckarchery is offline
Talking Lombardini 10hp diesel in a 147?
Okay I know some people will not like the idea, but I have plenty of Kubotas to do big stuff with. I just want to put a recoil start diesel in it. I am not worried about cutting the frame and getting it to fit and bolt up. I can handle that.
Any recommendations or thoughts about this? I tried a 6.5hp gas and it had to much resistance on the output shaft to get started. The tranny in my 147 works perfectly. Nothing wrong with it.
Old 04-02-2016, 08:18 PM
A pull start hydro sounds like a huge pita, if you could put a disconnect on the driveshaft so you could start it without turning the trans it might not be to bad.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-02-2016, 11:07 PM
Would that be basically a clutch?
Old 04-02-2016, 11:48 PM
gt383mag's Avatar
gt383mag gt383mag is offline
some of the cub cadet diesels came with a disconnect clutch. was on the back of the driveshaft im guessing acted like a centrifugal clutch so you werent turning the trans while starting the engine
Old 04-03-2016, 12:41 AM
bocephus1991's Avatar
Some of the hydro quietlines had disconnect clutches too. I saw a video of a Massey garden tractor with a one cylinder lombardini diesel in it. Was a ballsy little tractor! I was recoil start. The guy was at a plow day with it. He did about get ran over and the end by a red cub though! Lol
Brian
Old 04-03-2016, 08:24 AM
mickb72 mickb72 is offline
Default cub
Yes, could be. I thought about doing that to one. That way it would be ready if you wanted to put a gear trans in it. I think it would be better than the disconnect clutch some came with. Mike
Old 04-03-2016, 10:55 AM
What size are those wheels and tires??
Old 04-03-2016, 10:35 PM
gt383mag's Avatar
this guy has a few of those disconnect clutches
http://madison.craigslist.org/grd/5513994987.html
Old 04-04-2016, 10:58 PM
Thanks alot
Old 04-04-2016, 10:59 PM
Thanks alot
