Old 04-02-2016, 09:59 PM
cjet69's Avatar
cjet69 cjet69 is offline
Default Mowed with the Cub Cadet 1450, then it Quit
The 1450 has been sitting for a while and since it was a nice day I decided to do some mowing in the orchard. Had to charge the battery to get it to start. Got that done and went on to mow some rushes in a small pasture. Just as I finished the engine sputtered and died. When I tried to start it the starter would not engage. So to get it back to the shop I fired up the Farmall A, hooked up the tilt trailer, and retrieved the 1450. This happened yesterday.
Now today I checked the battery and it was good. The starter would spin, but still wouldn't engage. I tapped lightly on it with a hammer and it now the starter works. Now that it turns over I was able to check for spark. I got nothing. I then gave the points a quick dressing and still no spark. I guess I need to check out the condenser and coil next.
CC 1450, 44A deck, #2 tiller, 42" plow/blade
CC 124
CC 1220
#2 Cart
Old 04-02-2016, 10:23 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
My 1450 did this awhile back it turned out the connector on the key switch was bad. I had 2.5 volts making it to the coil. I ended up getting a new connector and terminals from john deere.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 04-02-2016, 11:52 PM
cjet69's Avatar
I checked voltage to my coil and it was battery voltage. Then checked at the points and got nothing opened or closed. Swapped a coil from a John Deere 214 and we are up and running.
CC 124
CC 1220
#2 Cart
Old 04-03-2016, 01:36 PM
cjet69's Avatar
Got the voltmeter out and checked the coil. It was open on the - side to plug wire and between the +/- terminals. The + side to plug wire read 8.13k ohms. Looks like an open coil was the problem.
CC 124
CC 1220
#2 Cart
Old 04-03-2016, 02:08 PM
