Old 04-04-2016, 03:15 PM
ka9egw ka9egw is offline
Default 1x8 battery compartment
OK, reassembling my 1x8...can anyone please post a clean pic looking down into the battery compartment? I have the oem battery hold down, with the kickup in the middle and the two little pieces and angle stock that just bridges the battery...but I'm not having any luck figuring out how the heck it's supposed to go in there...the hole in the back of the battery compartment it about the right height for the j-bolt on the loop end of the holddown, but then what do I do with the angle-bend end of the holddown?
Old 04-04-2016, 03:34 PM
JLM78 JLM78 is offline
Some of the new batterys will not let you run stock hold down
Old 04-04-2016, 03:35 PM
You are correct, the j bolt goes in the hole in the rear. The other end just hooks under the lip on the fender pan.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-04-2016, 03:45 PM
pics of battery
Old 04-04-2016, 04:43 PM
THANK YOU so much for the clarification! My train of thought: "Has to be that battery's too tall. Nah, couldn't be, I got a 108 and an 1811 and both use same [Farm and Fleet] battery. But one came with a bungee cord...and the other with a piece of foam rubber...I could grind down the hook on the hold down...but that means moving the tractor out in the cold to get to the grinder...I know! I'll try that crappy aftermarket NF hold down! It ought to work with those two unused holes in the top of the frame rails!"--which it did.
Now off to assemble the plow...
Thanks again!
Brian aka "Lurch" aka KA9EGW aka AAR5HS
