Question: Started Cub today and white smoke pour out exhaust and engine stalled like it is out of fuel after 8-10 seconds!
oil was coming out of exhaust on left cly took fuel filter off it is okay checked air filter is new and clean checked motor oil it was at full line a very clean Hours 126 Oil Change at 120 checked carb and found gas in botton of 90 under air filter hose inlet checked solenoid on bottom of fuel bowl clean lose not gummed up At a loss here what you think? |
Need more info. What model Cub? What engine?
Sorry
It is a 2006 Cub Cadet LTX-1050 Kawasaki 22HP Engine air cooled Cub Cadet2.jpg cub4.jpg Kaw 22.jpg |
Pull the plugs and see what ya got
What he said. Normally blowing oil out the exhaust is a bad sign. Like a hole in a piston. Don't see a lot of issues with the Kawi engines.
Also pull the tins...I have seen a few of these overheat due to clogged cooling fins.. Like Sam stated with the piston, make sure you have compression in the Left Bank... Could be an out of spec valve lash or valve sealing issue... Start simple and work your way into it..
If you have stuck rings etc... you could squirt some marvel mystery oil after removing the spark plugs and let it sit over night and then fire it up in the morning and see if that helps.
Or try spraying seafoam into the air intake and let it sit for 15 mins and try starting the engine again... |
