hello cub cadet fans . new to the forum , have been reading alot of good info here already .
i just got my first cub, a 1641 with 48 inch deck hydro lift and snow blade . free , blown motor and hydro leak . found drop in ready, used motor . installed and purrs nice . the leak is around relief valve for lift . o- rings appear good . lift still worked .cleaned valve and replaced . need to remove $$$ cub fluid and replace with something cheaper . from what ive read so far , hy-tran fluid is the way to go. local new holand /only equipment dealer has mastertran 134 . any feed back would be greatl appreciated . thanks alot and have a good one . ![]() |
Welcome to OCC! You can use the hydraulic fluid from Advance Auto or Tractor Supply. I used it in an 1872, and had no problems. I can't remember the name of it, at the moment.
Welcome to OCC!
The HyTran equivalent at TSC says so. That being said I would just find a CaseIH dealer and get the real thing. But it's your tractor so do what you think is best
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
How much for the blown motor?
im going to keep the old motor for parts . electrical mainly as it locked up tight at full throttle the way i understand . bent push rods like straws .
i got a jug of RK fluid . it will work until i get it all sealed up. then maybe upgrade fluid . $17 compared to $47 . i hate pumping money out on the ground . |
