Old 04-24-2016, 08:44 PM
Default Plastic cleaning ideas.
I'm looking for ideas to remove the gas stains from the plastic on the IH Lawnboy, I was going to paint it but it work really good under the pines trees so I think I might leave it as is if I can get rid of the stains. The area is part smooth and part textured so wet sanding and buffing it is out.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-24-2016, 09:19 PM
try a little muriatic acid on a small area and see what happens,use a Q tip
Old 04-24-2016, 09:44 PM
A Mr. Clean sponge/wipe really did an outstanding job on my soft cabs and made them look like new.
Old 04-24-2016, 09:45 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Or white vinegar if you're not up to buying a whole bottle of muriatic. Test first with ear thingy. Another thing is Meguire's (sp?) paint cleaner.
Plow blade
#2 Cart
QA36 snowthower
Old 04-25-2016, 12:18 AM
bocephus1991's Avatar
Vinegar, baking soda and a tooth brush. Or you may try the stuff they use to whiten teeth? May work, I don't know. Wouldn't think it would hurt anything.
Brian
Old 04-25-2016, 09:35 AM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
For plastic and staining from a hydrocarbon, I would give anything with hydrogen peroxide a try. It will bleach mildly as well as attack any residual carbon based material.
Give the Oxy clean stuff a try, give some time to let the peroxide do its thing, maybe 10 mins or so.
If you can get your hands on 35% peroxide (it's pretty restricted now due to its power and likability with the mujahideen), put some on with a tooth brush and scrub in for maybe 2 mins max and rinse. Don't get on your self unless there is some skin you want to first bleach, then extricate.
Old 04-25-2016, 11:18 AM
Thanks for the suggestion, hopefully I get some time this week to give them a try.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-25-2016, 09:24 PM
IMO try fantastik first. If that doesn't help go tougher.
Old 04-26-2016, 01:49 AM
The 35% peroxide I got from a cleaning supply "facility" after you apply it, let it sit out in the sun for a couple hours, it'll be oh so white.
Old 04-26-2016, 11:02 AM
Since I'm in the chemical field, I got my hands on some 50% peroxide. Pour a bit of that on a wood pallet and it chars first in a few seconds and spontaneously combusts. Pretty cool!!
The 35% on wood will char it black but no flame. They are both pretty powerful.
