Old 05-01-2016, 05:21 AM
oldyellow oldyellow is offline
Default Early bolt-on mower attach frame 102
I'm having difficulty putting on my mower deck, on my 102. I plan to use a cast end 38in deck. I would like some pics that would help me. I cannot find illustrations of such. I mean a picture of one installed properly with all details. I would like to keep as original deck and attach frame being bolt -on type. I have the 102 hoisted up to better work on his part.
Thanks for help.
Old 05-01-2016, 06:48 AM
Go here and down load the owner's manual........... Manual
Old 05-02-2016, 04:55 AM
Default older cast end decks
First thank you.The Manual is for the QA quick attach decks and frames.I already have that Manual.
I am working with the cast end decks and the bolt-on attach frames,no frankenstein bolts used on these.I believe I have heard them called that.The deck front would be held with two eye-bolts.
I have parts and pieces of these frames and a couple decks.A pic of such frame under the
tractor would even help.
These mower attaching frames were used very early.
Thanks guys for working at it for me.
Old 05-02-2016, 06:19 AM
Sorry, I'll see if I can dig into that.
Old 05-02-2016, 08:10 AM
Manual sent to the e-mail address listed in your profile.
Old 05-03-2016, 04:25 AM
Thanks,I am laying under the 102 a lot to figure the proper mounting and adjustments.Dad had a 104 years ago which did for sure use the same old cast iron ends deck and subject attaching frame.(bolt on,not quick connect and no latch on the front)
I never had any reason to work on it!
Anyway,if I figure it out,will let you know also.
Appreciate your efforts
