Old 05-13-2010, 05:34 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Default Electric Lift on a 129
I finally found a COMPLETE setup for my 129. Even has the float lockout pin.
Took all of 30 minutes to install. I still have to remove the handle from the side of the tractor, and install the bracket.
Pat Benner Haskell OK
Old 05-15-2010, 08:56 PM
Amigatec's Avatar
I really like the electric lift, I was in some tall grass today and it was much easier to raise and lower the deck this way. I have decided to leave the manuel lift arm on the side. With the handle locked in float it works fine, and I can tell how high the deck is as well. And where the discharge shoot get plugged up, it makes it easier to shake the deck up and down to remove the grass.
Also somebody had added a couple of bolts through the top of the deck where the cast iron piece goes and it was hitting the lift assembly. I removed those and the deck raises much higher now.
Old 05-16-2010, 12:36 AM
Nice electric lift.....how do you operate it without converting your rockshaft?
Old 05-16-2010, 07:43 AM
:biggrin2.gif:
Pat:
As the older I get, the more I appreciate the Hydraulic Lift on my Cubs as opposed to the "armstrong" method.
Old 05-16-2010, 08:43 AM
Amigatec's Avatar
I just put the handle on float.
Old 08-03-2010, 08:00 PM
martin1b martin1b is offline
Did you say you're not using the rockshaft? I'm looking for a rockshaft. Let me know if you want to sell it.
