Hi, getting a 147 in tip top shape. Saw that the gas tank just had a petcock stubbed into it and no sediment bowl. I put one on which required using a close nipple, so I am wondering was this a factory design? The sediment bowl sits right on top of the coil making it slightly difficult to remove the bowl. Great running machine that still needs a few odds and ends I was just curious about this, thanks for any info
-Rick IH 782 IH 126 CCC 1863 |
It prolly has a replacement motor in it,most likely for a wide frame.
I have seen the gas tanks turned 180 degrees and they used a pet cock and a inline filter.
Hey there,
Yes it is a replacement motor. The coil sits higher than the other narrow frames, so I imagine your right about it being a wide frame motor. I just had to buy back my 127 from my brother in law(turns out he's not a cub guy, or anything old) and the tank on it is rotated with an inline filter feeding a walbro carb.
Yup, that's how my 147 was when I bought it. Tank had the bowl on the right side and a ridiculous long line on it. When I turned the tank the correct way the coil was in the way. Solution was to lower the coil on the bracket as far as it'd go, and the coil wire actually comes into contact with the bottom of the bracket for the sediment bowl, but it works and looks pretty OEM for a cobbled up job.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
![]() Well.... it likely wouldn't EXPLODE... but there is a chance.
Looks sorta like this currently
![]() ![]() Been riding around like this for approx. 3+ years now. I'm not overly worried about it. Never really thought about it. I went out to the garage just now and worked the wire on top of the coil a bit so it doesn't ride on the bracket for the sed. bowl. I'll keep an eye on it, but not going to be paranoid about it. Thanks for the thought/concern.
Daniel that looks like maybe a replacement engine.
Or maybe just the shroud. An OEM 14hp would have the coil bracket bolted on the shroud at crankshaft centerline. And that decal would not be placed under the tank bracket. At lease all the 147's I have seen so far. |
Easy fix, replace the plug wire with one that has a 90 degree end where it goes into the coil.
Why not just loosen the clamp holding the coil and slide the coil down a little bit and tighten back up?
1966 Cub Cadet 122 1968 John Deere 110 1968 Cub Cadet 104 1971 Cub Cadet 107 1975 Cub Cadet 1650 2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree. |
Coil has been lowered as far as it can on the bracket.
