I just painted the coil covers for my car. I would like the letters to be black. how would you do this. I do not want the inside edges black only the flat part of the letter. I was going to use a brush but my hand is not as steady as it used to be. With all the wisdom and experience on this site I am sure some one will have a good idea.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
Start by painting the covers black, then use layers of stick on letters and pinstripe tape to do the logo, then paint the final color. Once the paint is dry to touch you use an exacto knife to cut around the letters and tape before pulling them off. Do any required touchups by hand before applying a clear coat.
Its a long process but I have done it, once, I dont have the patients to do it again. Good Luck
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
I'm no expert, but whenever I have a tedious job like that I have used a toothpick on its side with a little paint on it at a time and slowly go at it. Try it on something not as significant and experiment to see how it works for you. Others who have experience will likely have more informed ideas than mine. Just sharing with you my best practices and I hope it helps somehow.
I would use these dabber's I have to do the edges and then a larger brush to fill in the letter.
Oh my bad... I was thinking he needed to recreate the recessed effect... yes use the tiny dabbers, the paint will flow out to the edges.
you were correct I do want to keep the recessed effect.
Tim you better get some cream on those hands. Some one might think you work for a living.
Tim, try O'Keefes Working Hands, little green plastic jar. First time I haven't had busted hands in years, just went and bought my 3rd jar today. Got tired of the weather cracks in my thumbs...even works against thinner drying your hands out.
At work we sent some stuff out once for coating that had engraving that needed to be a different color. They used something that was cut and placed into the engraving, similar to a string, may have been a powder. Then they baked it in the paint/powder coat oven to get it to melt and flow out evenly. I'm thinking it is a process that goes along with powder coating.
Did a quick online search and came up with this: https://www.youtube.com/watch?v=Q4z5nu6PX6E Of course you could tape the walls and trim them with a hobby knife so you could spray it, might take all day to tape it and trim it
