Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 05-17-2016, 01:46 PM
rtdh01 rtdh01 is offline
Default 1782 intermittent shut down
I picked up a cherry 1782 '95/'96 year. with 1000 hours on it last fall. This season for no apparent reason, no warning lights and such, it has shut down, probably due to a signal from the overheat/low oil pressure protection. I'm new to the 640 as I've got a 782 gas with no bells and whistles. It does start right back up but the shutdowns are a PITA. Could it be an easy fix like wintered fuel gunk? Any help would be appreciated, Bob
Old 05-18-2016, 07:20 AM
I had an 1782 that did the same thing. Time to pull the fender pan and tank. Clean the tank, clean or replace the fuel shut off valves, replace the fuel lines and replace the fuel filters. Here is some info on how to keep your Cyclops happy.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244
