Old 05-21-2016, 04:07 PM
bocephus1991's Avatar
Default Broke the 1200 yesterday
Title says it all! Put the new driver and clutch in, mowed awhile. Then started rattling, then louder next a big you know what'n BOOM! Guess I had the clutch adj up too tight. It destroyed one pin on the driver, the new clutch, throw out bearing, teaser spring, the clutch arm and who knows what else. Was all my fault. I should have triple checked the clutch adj. Now I have an expensive mistake/lesson learned!
Brian
Old 05-21-2016, 04:08 PM
Here is another picture
Brian
Old 05-21-2016, 05:23 PM
mortten mortten is offline
Ouch. That hurts.
Old 05-21-2016, 05:54 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Ouch.
So you think the clutch arm was riding on the throwout bearing and not enough play in the pedal?
I want to make sure i avoid this happening to me...
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 05-21-2016, 05:55 PM
Wow, sorry to hear that.
Old 05-21-2016, 06:20 PM
Originally Posted by vr4Legacy View Post
Ouch.
Yes the throw out bearing was riding the clutch arm. I was thinking of replacing the arm and hanger. Now I don't have a choice! I just hope that the driveshaft is ok. Have to make a new pin for the driver. All it is, is a grade 5 bolt with the head cut off. And ground smooth.
Brian
Old 05-21-2016, 06:50 PM
twoton twoton is offline
Man, that's a bad set back.
Old 05-21-2016, 07:22 PM
Well that sucks. This clutch has been fighting you. Hope you get it figured out.
Old 05-21-2016, 08:48 PM
could have been worse,with the gas tank right above those spinning parts
Old 05-21-2016, 09:42 PM
Bob95065 Bob95065 is offline
With a plastic tank at that.
I don't understand how riding the clutch with a tight adjustment could cause this. I can see the disc wearing because of slipping but not a catastrophic failure like this. Can someone explain why this happened?
