Old 05-23-2016, 02:45 AM
Default Made some progress on a couple of projects.
It's been crazy busy in the shop the past few months but I somehow managed to make a little progress on a couple of projects that I've been messing around with.
I cabbaged the loaded 10.5 turfs with chains for another project last week from my 149 main mower. So I grabbed another pair of 10.5's off the rack to put back on it.
I broke them down checked the wheels and the inside of the tires put some tubes in them so I can load them later.
I had made up a pair of "weight holders" some time ago and thought this was as good a time as any to put them on.
I had to grind a little weld off of the two axle shafts in the 149, then prime and paint.
The pictures should pretty-much explain what happened after that.
Old 05-23-2016, 03:09 AM
I'll try to get some pictures tomorrow and tell you what I used the loaded tires on.
Old 05-23-2016, 08:36 AM
Lightbulb
Looking good Mark. Neat idea on doing the weights that way. Good grief you were up late though!
Old 05-23-2016, 11:33 AM
Good job, Mark!
Old 05-23-2016, 08:56 PM
bocephus1991's Avatar
Look good! I've stayed until that late working on Cubs before. I rebuilt a carb at 1am once! Heck 10pm-2am is usually the only time I have to work on my stuff anymore.
Brian
Old 05-23-2016, 09:28 PM
Mark,
Your are amazing!
Up to 534 and counting...
Old 05-23-2016, 11:16 PM
Well that right there is SLICK
Good job Mark.
Old 05-24-2016, 12:46 AM
I dunno Mike, ever since I got those two little puncture wounds in my neck, I find it difficult to sleep at night.
Mark,
Your are amazing!
Thanks for the kind words guys but I don't think this is anything new, I just did it a little differently than I've seen it done before. I do enjoy the heck out of making something useful out of something that would have otherwise laid in the junk pile for the rest of eternity.
Old 05-24-2016, 12:50 AM
I bought this 149 a couple of years ago for cheap, I thought it was going to be a parts tractor.
I got it home and did the usual things to make it run, the engine ran well and everything worked but it smoked a little more than I'm comfortable with. I found a couple of vertical scratches in the cylinder wall so I decided that I'd rebuild the engine and decide what to do with it later.
In my spare time during the winter of 2014/15 I rebuilt the engine, since I absolutely did not need another 149 it all sat until early this spring.
In the back of my mind I kinda had a plan for it but nothing was carved in stone yet.
Old 05-24-2016, 12:56 AM
Terry C's Avatar
Terry C Terry C is offline
That's pretty cool Mark!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
