Old 05-15-2010, 09:38 AM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
Default Rear Tiller?
Was wondering if I should use the float lock out pin on my 1650 with the rear tiller or not. Would it even make a differance since the tiller floats on the lift chains anyway. Someone told me the float lock out was for front and rear blades and plow.
Old 05-15-2010, 07:36 PM
Merk Merk is offline
The lock out pin is not needed when you use a tiller. It won't cause any problems if you have it in your Cub.
I don't use the lock out pin when I use my front or rear blade. That is a good way to break a pin in the lift system.
If you have the correct arms on your sleeve hitch adapter and your plow is set right you don't need lock out pin to plow.
