I am trying to time my rebuilt engine but nothing seems to be working right .how do I find the right stroke on these things . I have no problem with big engines but this little bastard is kicking my but . Nothing seems right and I don't know if the act is stewing me up
Have you got the Kohler K Series Service Manual...??
I think I have it I am trying to get the ignition timed right I think I have it at least I hope . I am rolling the motor over and when the points break they make my digital ohm meter go to open line . I have 301 with the head off and I think I made sence of everything when exhaust valve opens when air fuel charge enter and when compression and combustion go
Here is how you time them: http://www.onlycubcadets.net/forum/s...ad.php?t=33461 |
Did you line up the timing marks when you reassembled it?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
If I knew what I was doing I would my be on here confusing the heck out of us . what I was trying to figure out is the compression stroke and making sure that I was breaking the points at the right time so that I have fire so it will run . My ohm meter is digital so it is either measuring resistance or o.l. Open line what I hope is that as I was turning the crank it was measuring resistance and when it hit the sp mark it broke the points which my ohm meter goes to o.p. . Is that right ?
If I'm following you correctly, you are trying to set ignition timing. If the points break when the mark on the flywheel is in the window on the air shroud, you should be right. Search for static timing here on the forum, also check the resources section, probably a service manual for that engine here also.
It is easier to set points by doing it my way. While watching the points-points push rod I will rotate the crank until the points are open are far as they can open. Using a feeler gage set your points so they have a .017 to .018 gap. Your Kohler should start and run. You can do one of the following: 1. Run as it is 2. There is a slot in the points that you can fine tune your Kohler while the engine is running. 3. Find max point gap and change the thickness of the point gap. This is the way I have done it for almost 50 years.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Thanks everyone you guys are great . This is first k series rebuild I do a couple more I will be a lot better at it , ya know practice makes perfect ...
